March 10, 2022 at 5:56 pm
afshiin.a
SubscriberHello.
I analyzed a graphene waveguide in FDE solver. Then I got the confinement factor value. Why is the confinement factor value negative? What is the cause of this problem? I expect it to be zero, not negative, eventually!
Thank you
March 11, 2022 at 8:08 pmGuilin Sun
Ansys EmployeeGraphene is very thin and you are calculating the result through discrete algorithm. such error on the order of -5 is reasonable. I think I have replied you in another post. Please be patient and only post your questions in one Forum, English or Chinese. Otherwise the very limited support resources is wasted.
- Error on Lumerical device
2688
2138
1351
1136
462
