July 3, 2019 at 2:09 pm
cryptonary
SubscriberHi all.
I am trying to simulate a conical-shaped pin (male) being pressed into a hexagonal cylinder female part, both made of copper. However, I don't understand the resulting contact pressure between the two parts. More specifically, there seems to be concentrations of contact pressure, but I expect it to be quite uniform, throughout.
I have attached images of the geometry, boundary conditions and results (contact pressure and equivalent stress).
Any help is appreciated. Thanks
July 3, 2019 at 3:13 pm
Subscriber -
July 3, 2019 at 3:17 pm
SubscriberI would also suggest that you slice the model down to a 1/12 symmetry model. That way you can have three planes with zero normal displacement making for a very uniform support for the outer part. With much reduced volume, you can use much smaller elements. Make sure you are using quadratic elements that can represent curvature.
3744
2570
1787
1236
594
