December 8, 2020 at 7:53 am
Krasa
SubscriberI am working conjugate heat transfer of channel which consist of two fins and I applied vibration to channel to investigate the effect of vibration on convective cooling. I used structured mesh for channel and unstructured mesh fluid domain ( due to the use of dynamic mesh).nI am getting an error in my simulation. after some iterations I am getting AMG solver divergence - temperature error. nn I have tried with reducing time step and well as reducing relaxation factors, but error is still coming. I think problem is my mesh. because I have higher skewness in my mesh. nnHere I have attached my geometry as well as my existing mesh. could you please suggest me a method to obtain a fine mesh and run my simulation without any error?n
December 8, 2020 at 4:34 pm
System_delete
SubscriberThis discussion was created from comments split from: Divergence detected in AMG solver and floating point exception in ANSYS Fluent. -
December 8, 2020 at 4:36 pm
Forum ModeratorLooking at the mesh, is the fluid in the lighter grey tet volume? If it is, you need to do the tutorials on meshing and the Fluent solver, paying special attention to mesh resolution: 1-2 cells across a gap is too coarse and also look at leaving space before & after the obstruction. n -
December 9, 2020 at 8:37 am
December 9, 2020 at 12:13 pm
Forum ModeratorAnd how does that compare with this ?n -
December 9, 2020 at 12:50 pm
Krasa
Subscriberactually they used cutcell meshing method but I want unstructured mesh for fluid domain due to the smoothing and remeshing settings which I used in dynamic mesh.n -
December 9, 2020 at 2:22 pm
Forum ModeratorAnd the domain size? n -
December 10, 2020 at 4:41 am
Krasa
Subscribermy fluid domain is 112 x 31 x 37 mm and inside that domain I have heat sink with dimension of 100 x 15 x 32 mmn -
December 10, 2020 at 10:09 am
Forum ModeratorAnd compare the amount of space around the heat sink in the tutorial. In a flow experiment how close would you put the item of interest to the inlet/outlet? n
- The topic ‘Conjugate heat transfer’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
