November 15, 2023 at 5:00 pm
Sarah Mortazavinia
SubscriberI am simulating the heat transfer between flow and a thin solid in CFX. Mesh in the solid domain is not good and I want to use the approach of NO_SOLID as in Fluent. I found this documentation about fluent, but just wondering if that is also doable in CFX.
I noticed that with no solid in CFX, the inetrface can not be treated as a wall with heat transfer through it.
Any suggestion please?
November 17, 2023 at 8:33 am
CFD_Friend
Ansys EmployeeHi Sarah,
Try not to include the solid domain from the default domain location. And then try using Thermal Energy as the heat transfer option for the domain. This will allow the usage of any thermal boundary conditions.
November 20, 2023 at 2:04 pm
Sarah Mortazavinia
Subscriberthanks. I have a case where I have to simulate flow inside a pipe and consider fluid, pipe wall (steel) and then insulation material. I am confused between the thin wall approach and with-solid approach.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8834
4658
3159
1688
1482
