Conjugate Heat Transfer problem in CFX for a rotating domain
    • mcoderon
      I have a Conjugate Heat Transfer problem in CFX for a rotating domain that. There is a wall that I want to set as counter-rotating, but it's also part of a Fluid-Solid interface. How do I specify this wall boundary condition in CFX-Pre?n
    • rfblumen
      For a Conjugate Heat Transfer CHT) problem involving fluid-solid coupling through a fluid-solid interface, and if on the fluid side of the interface the wall is a counter-rotating wall, you would set the rotating wall condition under the fluid side of the interface (located in the tree outline under the fluid domain) under Boundary Details.n
