September 20, 2023 at 7:50 pm
javat33489
SubscriberHi all. When we extract the beams, we get lines. How can I connect beams with their bodies after creating the mesh?
Red - line, beam
Black is, for example, a square pipe that has become a line, but if you build a mesh it looks like a pipe again
Blue - how to set this contact?
Can I set this contact by highlighting the grid nodes?
September 20, 2023 at 8:35 pm
Ankush Choudhary
SubscriberHi Javat,
Please watch this video from one of the ANSYS channel partners.
September 22, 2023 at 6:30 pm
javat33489
SubscriberThanks for the answer. But this doesn't suit me.
Look, initially we have two solids, these are two beams. We extract rods (beam elements) from them and they become lines. Now that we have created the mesh, they will again look like beams as before the drawing. Now these beams need to be connected behind the walls, how to do this?
September 22, 2023 at 6:45 pm
Ankush Choudhary
SubscriberHi Javat,
If you have extracted them as beams, then these are not actual faces for which you can create a contact between them. If you want to create a contact between the two beams, then you have to select these two line bodies to create a contact.
September 23, 2023 at 4:14 pm
javat33489
SubscriberThis is my question. Is it possible to create a contact on phantom faces? If I create a contact on line elements, the contact won't see it. Make a large pinball radius?
September 25, 2023 at 6:00 pm
Ankush Choudhary
SubscriberHi Javat, You need actual faces to create contact between them. These faces cannot be used for creating contacts. You can create contact on the lines; they will work fine.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
