July 8, 2022 at 12:51 pm
aitor.amatriain
SubscriberI would like to know how can I connect (couple) two adjacent shells created with the shell conduction model.
Thank you
July 8, 2022 at 5:20 pm
Karthik R
AdministratorHello,
Are you attempting to connect these shells that are created on two different face zones? Could you please share a screenshot of where you have these shell layers?
Thank you.
Karthik
July 11, 2022 at 10:52 am
aitor.amatriain
SubscriberHello,
I cannot paste images, nor links, nor anything different than words because I always get the same error:
You don’t have permission to access “http://forum.ansys.com/forums/reply/218180/edit/” on this server.
Reference #18.55ae0017.1657536873.15ab80a8
The situation is that I have two wall zones (Wall 1 and Wall 2), each one including shells from the Shell Conduction Model, and I want to couple one layer from the shell conduction of Wall 1 with another layer from shell conduction of Wall 2.
Thank you
July 11, 2022 at 2:13 pm
Ansys EmployeeShell conduction should allow heat to pass into neighbouring shells. However, it passes into the same layer, so regardless of what is set up layer 2 will pass heat to layer 2 in the adjacent shell. Check the documentation to confirm.
July 12, 2022 at 7:57 am
aitor.amatriain
SubscriberI can create a dummy layer of infinite thermal conductivity to solve that.
However, I do not see any information in the documentation regarding how to couple adjacent shells.
July 12, 2022 at 9:50 am
Ansys EmployeeIt's automatic, check on here as I'm fairly sure I answered this in June.
July 12, 2022 at 10:00 am
aitor.amatriain
SubscriberIt was answered that the shells are adiabatic:
and I have checked that by simulating a simple case, but I have not received any answer in order to couple the shells.
July 14, 2022 at 1:40 pm
Karthik R
AdministratorHello,
Just to understand, are the two walls (wall 1 and wall 2) coupled to begin with?
Also, you should now be able to post images in your post.
Karthik
3862
2639
1859
1254
600
