Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Connection of two fluid zones
    • Maxim Fomichev
      Hello guys, I am modeling a cooling tower and ran into the problem of how to connect the two fluid zones. I have a cooling tower placed in a cylindrical calculation area. The calculation area has an inlet and an outlet. The cooling tower so has an inlet and an outlet, how do I make the air flow from the computational domain into the cooling tower through its inlet?
    • Nikhil Narale
      You can basically set the inlet of the cooling tower as 'internal' and give, for example, pressure outlet condition at the outlet of the cooling tower.
