June 29, 2023 at 4:50 am
Lee ChangHa
SubscriberHi. I'm a beginner at Ansys. I want to use anansys fluid. There is a license server on another PC, another PC, and that server is working well. However, when I run workbench, the error message box as below appears.
"Connection timed out while reading data.
The application has stopped waiting for a reply.
The license server may be experiencing a high demand or a temporary outage. Try again later."It was judged that it was not a normal situation for such a message to occur, and issues on the same problems were identified.
https://forum.ansys.com/forums/topic/connection-timed-out-while-reading-data-3/
https://forum.ansys.com/forums/topic/license-problems-connection-timed-out-while-reading-data/
https://www.youtube.com/watch?v=XIh47MZG__A
1. The PC that is causing the problem is different that it is not a server PC, and I couldn't find ansysli_server.exe and lmgrd.exe in programs that I could add to the exception of firewall. So I tried adding ansysliZ_client.exe just in case, but it didn't work out.
2. As you can see in the picture below, the license server setting test result is normal. Also, I received a reply from the license server management team that the server is running normally.
3. I also tried changing the settings of ansyslmd. There is content about SERVER, but there is no content about ANSYSLI_SERVERS, so I couldn't change the settings.
4. I also checked the comments below and tried to change the setting variable, but I couldn't find ANSYSLI_TIMEOUT_TCP.
if anyone facing ANSYS license Server timeout issues.
Add the below environment Variable in your account
Value : 300
It will resolve your issue.
5. In this situation, when I turn on the workbench, the following error message occurs twice. Is this a normal situation?
Maybe it's the wrong question because I don't have enough knowledge about licenses, but I have questions.
Could it be a problem with the license server in this situation?
For example, could it be a problem because the port is not opened, or could it be a problem because it is not designated as a license-enabled IP?
How can I solve this problem? -
June 29, 2023 at 5:00 am
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7552
4424
2949
1414
1322
