December 10, 2020 at 6:03 am
Ajayc1160
SubscriberHello Dr AminenOne more question. Is it possible to provide a constant pressure B.C on a wall (i.e wall to be maintained at specific pressure always) and also a negative source term on the wall?nI am aware that negative source term on the wall can be provided by using UDF but not if latter can also be added. What I am trying to do here is I want the pressure on the wall to be maintained as saturation pressure corresponding to given temperature B.C on the walln -
December 10, 2020 at 9:29 am
System_delete
SubscriberThis discussion was created from comments split from: UDF for definining saturation temperature as a function of pressure. -
December 10, 2020 at 9:31 am
DrAmine
Ansys EmployeeCreating a dedicated thread for this question. nConstant pressure at wall should be done via momentum source terms. nWhy do you require something like that?n
8762
4658
3151
1678
1456
