May 11, 2022 at 4:15 am
Dino
SubscriberHello,
My domain is closed. All sides are walls. Unsteady 2D. The domain consists of two zones. I want to assign a constant velocity inside one of the zones (the yellow zone in the picture). DEFINE_ADJUST, works OK and showed ~0.1 m/s in -ve y direction in the yellow zone but very hard to converge. So, I wrote a source term but it doesn't reflect the correct value of velocity when I solve for a few time step. I tried Fixed Values in the Cell Zone but the solution diverge after a few iterations. The value coming from the UDF is slightly less than half the expected value of 0.1 m/s in the contours.
May 11, 2022 at 8:52 amRob
Forum ModeratorIt's a momentum source, so it's being added to the current value in the cell. You may want to read up on the FIX cell zone condition, but note it'll be fairly difficult to converge and you need to avoid walls touching FIX zones as the wall functions conflict.
Viewing 1 reply thread- The topic ‘constant velocity momentum source term does not show the expected value’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
