April 7, 2022 at 1:16 pm
acukrov
SubscriberDear all,
with this message I would like to inform on the problem in setting the final position of a half-body during its immersion as a free fall (one-DOF translation). The problem is that the body goes outside the domain; instead of being stopped at the certain location before the domain's bottom is reached.
May 11, 2022 at 4:02 pmSurya Deb
Ansys EmployeeHello,
Check the reference location properly and then check the min and max from the reference point.
Why do you need an UDF to constrain this motion along a single direction?
You can actually test it through the GUI itself.
Regards SD
Trending discussions- Floating point exception in Fluent
8768
4658
3151
1678
1456
