LS Dyna
LS Dyna
Constrained_extra_nodes
    • javat33489
      Good afternoon. How to use Constrained_extra_nodes in WORKBENCH LS-DYNA? Will it be a snippet? Tell me please.
    • Reno Genest
      You can use LSDYNA Pre > Rigid Body Tools >  Rigid Body Additional Nodes.
      Reno.
      • javat33489
        its not work
        error:
        This Field is only available for Rigid Bodies : Rigid Body Additional Nodes
        Because this part is not rigid
    • Reno Genest
      The keyword *CONSTRAINED_EXTRA_NODES only works with a rigid body. This keyword is used to add nodes from a flexible body to a rigid body. This effectively connects the nodes from the flexible body to a rigid body. If you don't have a rigid body, this keyword will not work. Here is more information from the LS-DYNA user manual:
      If you want to connect 2 flexible bodies together, you can use a bonded contact (tied contact), use spotwelds, have a node to node connection via the mesh, or use joints. There might be other ways that I don't think of riight now.
      Let me know how it goes.
      Reno.
