June 30, 2022 at 5:49 pm
longt8
SubscriberHello,Currently, I am working on using *CONSTRAT_TIED_NODE_FAILURE to model fracture mechanics problems. The crack surfaces seem to fail in the y-direction first(see fig.1 attached) and then in the x-direction (the direction of crack propagation). In reality, this mode 1 crack should just fail at x-direction. I think this unphysical result is caused by the *CONSTAINT_TIED_NODE_FAILURE release the nodes with the plastic strain reached the threshold. It really should be when the plastic strain of any nodes in the tied node group reached the threshold, the node on the maximum v-m direction was released.Please let me know whether there is any existing keyword that can solve this issue, or if there is any user-defined option.Fig1. Effective Plastic Strain of a crack with *CONSTRAT_TIED_NODE_FAILURFig2. Von-Misses Stress of a crack with *CONSTRAT_TIED_NODE_FAILURE -
August 16, 2022 at 6:41 pm
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3862
2639
1859
1254
600
