Discovery Import
Discovery Import
Constraining Rotation DoFs
    • CNI86
      some of the degrees of freedom of the rotations in x, y, z should be restricted too, is this posible in AIM? thanks
    • Gaurav Sharma
      Hi Carlos_nys
      By default, the displacement BC in AIM has 6 inputs, 3 for translation and 3 for rotation.
      However, whether rotations can be restricted or not depends on what kind of selection is made under location. The solid elements have only 3 degrees of freedom per node (all translation and no rotation), so if your geometry is solid its not possible to restrict the rotations directly. It can be seen as you select this solid body or some of its feature as location, the rotation controls under displacement greys out.
      However, if you are working on a shell model, which has 6 degrees of freedom per node (3 translation and 3 rotation), it is possible to control the rotation through displacement input.
      Unfortunately in AIM, unlike ANSYS Mechanical, there is no remote displacement option which can help you control rotation even with solid elements.
      • CNI86
        Gaurav_ANSYS
        it is mandatory to define a symmetry BC  in a shell body  from the displacement dialog box instead of from the user-defined BC dialog box?
        Is possible define axisymmetry in AIM?
        Thanks you
      • Gaurav Sharma
        Carlos_nys
        I am sorry 2D axisymmetric analysis is not possible in AIM. You may like to post your suggestion in the ideas section
    • CNI86
      thanks you very much for your explanation.
      Regards
