Tagged: constraint, degree-of-freedom, flexible-body, ls-dyna, nodes
April 5, 2022 at 3:36 am
emarkowski
SubscriberIs there a strategy that can be used in Workbench LS-Dyna to constrain specific rotational degrees of freedom of a flexible body's nodes? For example, preventing nodes from rotating about the z axis, while remaining free and flexible about the other 5 degrees of freedom.
April 5, 2022 at 9:52 amViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
