December 9, 2022 at 8:59 am
Plebian Seth Tamba
SubscriberGood day, I'm currently doing a research about the structural perfomance of a non-monolithic column system . Is it possible to simulate a non-monolithic casting/construction joint in concrete using ANSYS?
December 9, 2022 at 11:39 am
SubscriberYes, you can use contact to transfer loads between the pieces.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
