May 27, 2021 at 3:03 pm
tsinghuaby
SubscriberHello, are there any application examples of FDTD particle swarm optimization algorithm in metasurface or metamaterial simulation? Can you provide relevant reference links?
How to use the optimization function that comes with FDTD? Can you give relevant reference instructions?
May 29, 2021 at 1:10 amKyle
I don't think we have any examples of the particle swarm optimization tool for metasurface or metamaterial simulations. However, some information and a few examples of how the PSO tool can be used can be found here:
Here is another example that uses the PSO tool to optimize the geometry of a Y splitter:
The approach for a metasurface or metamaterial should be similar: parameterize the geometry (a structure group might be helpful for this) and define a FOM that is a single real value for the algorithm to optimize.
May 29, 2021 at 7:43 amtsinghuaby
SubscriberThank you very much for your reply and answer!
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
562
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
