May 23, 2023 at 9:12 am
ceshi xiazai
SubscriberDear all,
I put a point DFT monitor to get the spectrum inside the pyramid cavity. I'm wondering why the intensity has a big difference between 2D and 3D FDTD region with everything else settings the same. Does the 2D FDTD region get a result by regarding the structure as a hexagonal prism rathan than a hexagonal pyramid ?
May 23, 2023 at 10:02 am
ceshi xiazai
SubscriberFor this case Whispering gallery modes of a microdisk – Ansys Optics
2D FDTD region is conducted while the structure is a pillar. So does this structure be regarded as an infinitely long prism?(because there is no PML restriction in the z axis。
May 23, 2023 at 10:04 am
ceshi xiazai
SubscriberAnd I'm also wondering why a 2D FDTD simulation region was adopted in this case
May 23, 2023 at 4:03 pm
Amrita Pati
Ansys EmployeeHi Ceshi,
You can use 2D simulation region if the structure has a translational symmetry along one of the axes. In your case since the structure is not uniform along the third axis, a 2D simulation region should not be used. If it was a hexagonal prism of infinite length then 2D FDTD would have been accurate. So, for 2D simulation you can assume that the structure is infinitely long and uniform.
Amrita-
May 24, 2023 at 1:12 am
ceshi xiazai
SubscriberThanks for your nice reply! I have another question. For this case Whispering gallery modes of a microdisk – Ansys Optics
the prism is not infinitely long(it seems to have a certain height),why can it use a 2D simulation region?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5268
3299
2469
