October 23, 2023 at 6:23 pm
Mehdi Saloo
SubscriberHello,
I have modeled three similar parts in contact. I assume that the parts are perfectly glued to each other. Therefore, in that case, I merged duplicated nodes in their interface to provide a tied contact condition. However, after delamination, the plies cannot see each other and pass through each other. I wonder if I can define an extra proper contact between the plies to prevent such an unrealistic behavior. I wonder whether the Automatic-Surface-to-Surface contact algorithm is a proper one.
I would appreciate it if you could give me some advice.
Thanks in advance.
Mehdi
October 25, 2023 at 2:51 pm
Jim Day
Ansys EmployeeLeave parts merged bu add a *CONTACT_ERODING_SINGLE_SURFACE with all three parts on the SURFA side. SURFB side should be blank. -
October 25, 2023 at 2:52 pm
Jim Day
Ansys EmployeeLeave parts merged but add a *CONTACT_ERODING_SINGLE_SURFACE with all three parts on the SURFA side. SURFB side should be blank.-
November 14, 2023 at 2:11 am
Mehdi Saloo
November 14, 2023 at 2:35 am
Jim Day
Ansys EmployeeYou've set SURFATYP to 3 so that means SURFA is interpreted as a part ID. To put multiple parts on the slave side, you must set SURFATYP to 2 and then you can set SURFA to a part set ID. A part set is defined using *SET_PART.
- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8736
4658
3151
1678
1452
