contact angle doesn’t change
    • ursen
      Hi!
      I'm having problems with changing of contact angle. In my 2D set up I've patch a drop. Since default contact angle (fluids are water and air) is 90° the first contour result is OK.
      But when I try to change it - for example to 120° - there is no difference. No matter what I do, the final result is the same. Drop with contact angle 90°. Any ideas why it doesn't work?
      Thanks
    • Karthik R
      Administrator
      What type of analysis are you running? VoF?
      Can you please post the pictures of the two drops? Are these steady-state results you are looking at? Or are you looking at the contours right after initialization?
      Thanks.
      Karthik
