Contact between the gear teeth
    • Sankar93
       Which type of contact should be used between the gear teeth?
    • Aniket
      It all depends on case to case and relative motion between gears. The ideal scenario would be frictionless contact, which would not be the case in actual so there will be some friction.
      -Aniket
