LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Contact breaking down. With large penertrations.
    • Ben_Ben
      I am inflating a bag like structure with a pressure. As seen here: bag before and after inflation
      It needs to contact with several other bodies. However, it fails to contact with some of the bodies.
      Here is an example of a successful contact: Before and After
      Here is an example of an unsuccessful contact: before, during and after
      Both of the bodies are marked as targets with the inflated bag as the contact. The contact is a simple frictional contact. I have tried frictionless but this didn't help.
      Here are my contact settings:
      Thanks,
      Ben
    • Ram Gopisetti
      Hi, i am not aware if you use any single surface airbag contact in your model, if not use it,
      increase the stiffness factors by using the lsdyna contact definition.
      cheers, ram
    • Ben_Ben
      How do I find the lsdyna contact definition? I haven't used single surface airbag contact in this model.
      I'm using Workbench LS-Dyna are these availble?
      • Ben_Ben
        I have found the lsdyna contact definition, what settings are you suggesting I change?:
        I am still using normal contact not single surface airbag contact
        Are you referrring to the airbag option under LS-Dyna Pre?:
    • Ben_Ben
      I got the contact to work by using a soft constraint formulation. Not sure why, but it works now.
Viewing 3 reply threads
