Contact-concrete-wood-rubber-steel
    • S_Takoe
      Hello! There are fragment of bridge roadway - concrete slab, that stayed on the wood-rubber gasket.
    • Ashish Khemka
      nnHaving the model setup closer to reality will give you more closer results to the field. The second approach where you model all the components may be more accurate approach. But you can model both approaches and compare the results to see the difference.nnRegards,nAshish Khemkan
    • Ashish Khemka
      nnCan you please comment if the suggestion helped you?.Regards,nAshish Khemkan
