November 8, 2023 at 6:40 am
Fady Elshazly
Subscriber -
November 9, 2023 at 2:43 pm
Aniket
Forum Moderator-
November 9, 2023 at 5:49 pm
Fady Elshazly
SubscriberHello,
I am using Automatic contact surface to surface to model the contact between two objects in LSDYNA. the first one is a horizontal mat with prescribed three components earthquake. The second object is a cylinder overlying this mat. Under the input motion,the mat starts moving and the cylinder starts moving and may have an uplift. Is there a way to check the contact any type of results to know if there is a total uplift (separation) between the two objects meaning that no contact points between both objects.Thanks
Thanks
November 10, 2023 at 2:47 pm
Alex R.
Ansys EmployeeHello,
In the desribed case it would be recommended to define the mat as SURFA and the cylinder as SURFB in *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE (SURFATYP = 3, SURFBTYP = 3). Adding keyword *DATABASE_RCFORC will provide a data about contact forces between the mat and cylinder.
Please let me know how it goes.
Alex
- License Error
- how to open DesignModeler
- FlexNet Licensing – Not running
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
- Numerical Problem Size limits with a model that should run
8808
4658
3151
1680
1470
