Contact stress and bending stress of gears
    • shrav007
      What is the correct method of finding contact stresses and bending stresses of two gears in static structural ? Some research papers have put Moment and frictionless support at the driving gear and fixed support at the driven gear. Is this method correct ?
    • peteroznewman
      Yes.
    • shrav007
      Is there any other method ?
    • peteroznewman
      You could swap them. Fix the driving gear, put a negative moment on the driven gear, but you will get an almost identical result.
    • shrav007
      Thanks a lot
Viewing 4 reply threads
