January 28, 2021 at 5:04 pm
ah05085
SubscriberHello all,
I'm struggling to move forward with my modal simulation. The part where I'm stuck is acquiring contact tool initial information. The error message I'm getting is you have a contact tool with invalid contact selections or result request. The warning regarding my rotor is for this tabular bearing to be effective, make sure there is a associated rotational velocity defined in the respective analysis. The initial information worksheet window isn't providing any information and filled the tabular data with rotational velocity, spring, and damping info.
January 29, 2021 at 1:19 pmAshish Khemka
Ansys EmployeennAnsys employees cannot download the attachments. Can you please share the snapshot? Can you try deleting the Contact Tool and then reinsert the same?.Regards,nAshish KhemkanFebruary 1, 2021 at 11:49 pmFebruary 2, 2021 at 9:16 amAshish Khemka
Ansys EmployeennLooking at the error for the contact tool it looks that you have selected an entity for which initial information cannot be provided using the contact tool. On the warning message I think the message is self explanantory.nnRegards,nAshish KhemkanFebruary 4, 2021 at 1:18 amah05085
SubscriberIts unclear to me where to input rotational velocity. I've inputted this data in two different locations. nMarch 18, 2023 at 2:19 pmAslam
SubscriberI am creating Contact of Line bodies to Faces of Solids. Message popedup is "Invalid contact selection or results requests. Your help will be recognised.
March 18, 2023 at 3:36 pmpeteroznewman
SubscriberTry flipping the contact and target sides.
March 19, 2023 at 6:06 am
Aslam
SubscriberThank u, but Ansys says, Low dimensional must be Contact and Higher dimentional Target. ie. Point (Contact) to Line (Target), and Line to face.
March 19, 2023 at 1:18 pmpeteroznewman
SubscriberI had to know for sure which way you did it since you were not explicit in your first post.
The message says "or results requests". Delete all results requests and see if the model solves.
Viewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5204
3281
2459
