Discovery Import
Discovery Import
Contact with shell elements
    • mcarlet
      I have a problem with a contact between two parts modelled with shell elements.
      The two parts are connected with a bonded contact (edge/edge).
      When I start the analysis, I get an error message which reports a rigid body  motion.
      I will be grateful for any help you can provide. Thank you.
      Regards
      🛈This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Gaurav Sharma
      Hi crl_mb
      I looked into your model and can see that the problem deals with edge to edge contact in shell. This makes it a relatively tough problem for convergence.
      Further, I made a couple of changes which helped convergence.
      1. Used 2 separate bonded contacts for the two edges
      2. Increased the pinball radius.
      I am attaching the updated model for your reference. You can solve the system and see if this works for you.
      Best Regards,
      Gaurav
    • s251854
      We thank you for sharing your feedback. We will share your idea/input with the product development team.
