February 23, 2022 at 5:31 am
FaizanYounas
SubscriberHello there. I'm conducting a simple case of pool boiling. I have considered a simple rectangular domain with the bottom wall as super-heated. I'm using the VOF method with the Lee model. The results are normal and what I was expecting. But, the problem I observe is the continuity is not converging. The key point to mention here is when I change the scale of my geometry (2cm by 1cm) the continuity does converge. But, when I change the geometry units to mm (2mm by 1mm) this problem arises.
Does anyone have an idea what could be the reason for this behavior and especially how to avoid this?
February 23, 2022 at 8:35 amDrAmine
Ansys EmployeeMore important to check if you mass imbalances if the domain is closed. Also judge the convergence of every time step by monitoring key quantities on top of residuals and imbalanes.
February 23, 2022 at 11:57 amFaizanYounas
SubscriberNo, my domain is not closed. There's a pressure outlet boundary condition at the top. Also, if I initialize the solution at the subcooling temperature the continuity does converge. But, only till the vapors starts to form. As soon as the nucleate boiling starts, the continuity diverges.
February 23, 2022 at 1:32 pmDrAmine
Ansys EmployeeEven if it is open you can easily draw mass imbalance in the full system considering what comes in/out of the outlet. Moreover be aware that your result are depending on the Lee Coefficient you are using.
February 23, 2022 at 2:15 pmRob
Ansys EmployeeWhat time step are you using?
February 24, 2022 at 12:50 amFaizanYounas
SubscriberMy time-step size is 1e-7s (as it is a 2mmx1mm domain) to keep the courant number under 0.5 or 1.
February 24, 2022 at 3:23 pmRob
Ansys EmployeeDrop the time step an order or two in magnitude and see what happens. If the boiling rate is relatively high relative to the cell size you're creating an awful lot of gas when you change phase relative to the mesh.
February 24, 2022 at 3:37 pmDrAmine
Ansys Employee.
Viewing 7 reply threads- You must be logged in to reply to this topic.
2524
2066
1285
1096
459
