March 10, 2022 at 8:30 pm
A_I_
SubscriberDoes anyone know if it is possible to have a continuous change in the geometry of a structure in ANSYS Discovery? Rather than manually changing the geometry, is it possible to set a max and min, and have the geometry fluctuate between the two providing real-time results? Super niche I know, but I am wanting to somehow "mimic" a 3D printing process with real-time results. Any feedback or ideas on how to approach this would be greatly appreciated!
March 16, 2022 at 12:25 pmNaresh Patre
Ansys EmployeeHello In Ansys Discovery, you can get real-time results for geometry changes, but you can't have the geometry continuously changing while solving. One way to go about it is to perform a parametric study for different designs of the same geometry and analyze the results of each design.
- Naresh Patre
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
459
