Contour plot of stresses in a specific body of an assembly using APDL
    • Asatur
      Hello all,
      I am a complete novice in APDL. I am comparing the stresses (Transient Thermal + Static Structural) of a larger assembly for multiple geometries of its specific components. So, in order to be able to compare all cases on a unified scale, I need to adjust min and max values of stresses in all contour plots. I tried editing them directly on the contour plots. While the min value can be edited, the max value is not editable.
      Then, I came up with this post: /Contour Function on Mechanical APDL (ansys.com), which seems to solve my problem. However, I am not sure how to make /Contour work for individual specific bodies and surfaces.
      Any example or help would be highly appreciated. Thank you for your time.
    • Erik Kostson
      Hi
      So say we have two parts and added them (elements) into a component (use CM,CMENA,ELEM, and CM,CMTWO,ELEM ) and so we can select them separately via cmsel, then this plots (using /contour) stress results of them separately:
      /POST1
      SET, LAST
      CMSEL,S,CMENA
      NSLE
      PLNSOL, S,X,
      /CONTOUR,,,-11000,100,0
      /REPLOT
      /RESET
      ALLSEL,ALL
      CMSEL,S,CMTWO
      NSLE
      PLNSOL, S,X,
      /CONTOUR,,,-12000,100,0
      /REPLOT
      All the best
      Erik
    • Asatur
      Hi Erik,
      Thank you very much for your asnwer. So, if there are more than two objects, should I define them all? In fact, I have 49 objects. Would I need 49 blocks of this piece?
