September 12, 2019 at 1:57 am
Aoran
SubscriberHello
I have been doing the tutorials of fluent 19.0 of 22, called for the simulating a single battery cell using the MSMD battery model.
I am at the step 22.4.8.2 postprocessing, number 4 display the contour plot of the temperature as you did previously.
The contour was like the picture I showed below. And the second contour plot is what supposed to be on the tutorials guide.
I am using the desktop with CPU of 9900K and my graphic card is 2080ti, my monitor refresh rate is165HZ, so I believe is not quite my hardware problem. Besides
any rotate lead my contour shows up the same.
I just wondering if anyone had met the same problem, and what was the way to solve it?
You answer will be appreciated.
Best Regard
September 13, 2019 at 2:19 pm
DrAmine
Ansys EmployeeFirst of all check if you followed the steps in the tutorial. Second if you still face the same issue check with an actual release version (2019R3 or R2)
September 13, 2019 at 3:02 pm
Ansys EmployeeIn the contours panel turn OFF the Display Mesh option: I think you're displaying the same surface and it's overlapping the images.
September 16, 2019 at 8:29 am
Aoran
SubscriberThank you for being so helpful.
I realized that the problem is the "Drew Mesh" became a default setting for my contour plot box, which I didn't realized.
And which caused the overlapping? Thanks again to rwoolhou.
Best Regard
2564
2080
1299
1106
459
