January 5, 2023 at 9:43 am
dbt2dariomn
SubscriberHi all,
I just wanna know whether it is possible or if there is a command to constraint a displacement in only one direction, that means if I know that my assembly or piece cannot move in +Y direction but let -Y direction as free.
Kind regards
January 5, 2023 at 11:29 am
Ram Gopisetti
Ansys EmployeeHi, if you have face bottom to it or under the applied displacement or force set the displacment in the face to 0 and load the top face in y direction, this should do the job.
Cheers, Ram
January 5, 2023 at 11:32 am
Aniket
Ansys EmployeeAre you using Mechanical? You can try compression-only support for this. Or you may want to use compression only (or tension only) spring with large stiffness, which is a beta feature in Mechanical.
-Aniket
January 5, 2023 at 11:35 am
Ashish Khemka
Ansys EmployeeHi,
You can model an object in contact (frictionless contact) with the part of interest such that the object in contact does not allow the other part to move in positive Y and allows it to move in negative Y-direction.
Ashish Khemka
2120
1349
1118
461
