July 26, 2019 at 7:28 am
m.caragiuli
SubscriberHello,
I'm not able to insert a decimal number as a coordinate value in the mechanical structural. Each time I try to write for exemple 8,236 as soon as I press enter the value changes to 0 and if I write only 8 then it is accepted, but it is not correct as I nee the three digits after the comma.
How can I solve?
thank you for your time
July 26, 2019 at 9:38 am
jj77
SubscriberWrite 8.236 instead of 8,236 (so remove ,commas and use .)
July 26, 2019 at 1:40 pm
m.caragiuli
SubscriberHi, I've tried, but no way. However I solved by typing 8236e-3.
Thank you for your response!
I have another issue, more complciated about remote displacement, I wrote a post specific to that point, if you have time please have a look.
Thanks
July 26, 2019 at 2:37 pm
2120
1347
1118
461
