Convection and heat radiation simultaneously
    • Magyar03
      I would like to simulate the temperature distribution in a room with radiator heating. I think I need to consider radiant heat transfer and convective heat transfer of the radiator body.
      Can someone help, how to/where I can find something to learn about how to do the setup ?
    • Karthik R
      Administrator
      I'd recommend that you watch how to set-up the problem on Ansys Fluent. YouTube has several videos related to such problems. I'd recommend that you search on YouTube and this should give you a good place to start with.
      I hope this helps.
      Best,
      Karthik
