convergence
    • Ibrahimabdullah
      I am getting the following issue when running my simulation.. sometime it crashes and sometimes it goes smooth.. anyone has any idea? i used both k-omega-sst and SA models.
      my results are accurate according to the LR.
    • Karthik R
      Administrator
      What is your mesh quality - min orthogonal ratio and max skewness?
      What problem are you trying to solve? What are your solver settings?
      Thanks.
      Karthik
    • Ibrahimabdullah
      actually i realized that my Graphix card is not sufficient to run high number of elements thats why it keep crashing. im solving uav (flying wing) and i dropped the number of elements and change the residual from 0.0001 to 0.001 and it converged smoothly .. here is my mesh quality.
      i used SA TURBULENCE MODEL
      MACH 0.2 = 68 M/S AT AOA 20
    • Karthik R
      Administrator
      Perfect! Good to know!
    • Ibrahimabdullah
      THANK YOU SO MUCH
Viewing 4 reply threads
