Convergence difficulties due to abrupt stiffness change (ekill)
    • ElCid01
      Hello everybody
      I am running a nonlinear structural simulation with multiframe restart option in Ansys APDL of a sandwich structure which is loaded via a displacement control. After each load step I postprocess relevant data to know, if a core element during the simulation fails. If such a core element fails then I restart the simulation from the previous substep and kill the elements which failed with the ekill command. Problem is that, after deactivating the failed elements the simulation does not converge anymore. NROPT,full,,on has been set and also the time increment respectively the displacement increment has been chosen very small. Nevertheless no improvement of the convergence has been achieved. The problem of course is that the stiffness becomes very low after deactivating the failed elements. What I also tried is a simulation without the failed elements from the beginning but then the simulation converges and also a very large displacement and reaction force is achieved, which means that the before mentioned calculation should be possible, but I really do not know how to overcome the convergence difficulties.
      I would be very happy for any suggestions I could try.
      Thanks a lot.
      Best regards
      El Cid
    • Sandeep Medikonda
      Hi El,
      How does your force convergence plot look and what do the newton-raphson residuals (NROPT) suggest? Please see this discussion. Are they high in the regions where the elements are being deleted or elsewhere? If there is contact in your model and if the NR residuals are high over there, try reducing the contact stiffness. I would also recommend you to try using the Direct solver instead of the iterative one and see if it helps.
      Sandeep
    • ElCid01
      Hi Sandeep
      Since I am working with Ansys Mechanical I am not able to see this plots or I do not know how… I do not have any nonlinear contacts in my model, I only have nonlinear joint elements (MPC184) that are linked to the elements which are deleted. Therefore I cannot change any contact stiffness. To change the solver is a good idea, do you know which the standard solver is?
      Thank you for your advices, I will try them as soon as possible and comment.
      Regards El Cid
    • Sandeep Medikonda
      Ok, The default should be the PCG or the Iterative Solver. You can check this in the solution output.
    • ElCid01
      Hi Sandeep
      During these days I had time to implement what you said to me about changing the solver. I tried every solver out but without success. Attached you will find the convergences plots before the element are killed and afterwards. In the first picture I make a restart at the time 0.25 approximately, at this time the elements are killed because the stresses are too high.
      Thanks, best regards El Cid
    • jj77
      It is hard to say without looking at the model. As far as I understand it needs some manual intervention, or does it automatically remove elements and continue, or do you do that manually, and then continue. I believe that there is some script that does this automatically, think it is from peteroznewman, see here: https://studentcommunity.ansys.com/thread/i-want-to-see-the-failure/.
    • Venugopalb
      Hello EICid01!
      Can you tell me how to change the solver in ANSYS workbench. Because my model also gives unconverged solution.
      My professor asked me to change the solver.
      Regards
      VEnugopalb
Viewing 6 reply threads
