September 19, 2022 at 5:24 pm
Durga Parajuli
SubscriberI am modeling the Compressed Air Energy Storage (CAES) tank using ANSYS Workbench. The materials used are steel and Ultra High-Performance Concrete (UHPC). I am having convergence issues when non-linear concrete is used but for linear analysis, there are no errors.
Thank you.
September 22, 2022 at 11:13 am
Ashish Khemka
Ansys EmployeeHi Durga,
Can you please share snapshot of the solver output? In Mechanical generally when the default iteration value of 25 is exceeded then the solver exits the solution. If that is the case (you can check the cumulative iterations) then try increasing the iterations by using the command - NEQIT. For example - for specifying 100 iterations use NEQIT,100.
Ashish Khemka
September 23, 2022 at 8:26 pm
September 26, 2022 at 9:22 am
Ashish Khemka
Looking at the message it looks like analysis is continuing at your end using Sparse solver.
Ashish Khemka
- Changing of font size
- System Coupling
- ANSYS Workbench Mechanical Solver problem after saving
- 3D ROM in workbench
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- ANSYS Direct Optimization
- HARDWARE COMPATIBILITY
- System Coupling
- When I open the Electronic Desktop, Twin Builder auto opens
2656
2120
1347
1118
461
