TAGGED: ansys-mechanical, mechanical-apdl, static-structural
February 11, 2021 at 10:01 am
tolukumar
SubscriberFebruary 12, 2021 at 4:12 pmJohn Doyle
Ansys EmployeeYour material model setup looks generally correct for a coupled damage-plasticity Microplane model. The format looks same as the example offered in Section 4.8.2.2 of MAPDL Material Reference Manual, with some of the strength values modified.nThe warning message that you are showing in solver output is very general. It could mean that the code cannot establish where the stress state is on the yield surface. Have you bisected to the smallest time step size? This might be remedied by using more substeps, but I cannot tell from the output if you have reached the minimum time step size or what your autotime stepping specifications are. nAlso, what is the motivation for using the CPT215 element? Are you trying to define a pore pressure thermal simulation? Perhaps you need to change the strategy of the loading to make it more manageable to resolve. nFebruary 26, 2021 at 11:07 amtolukumar
Subscriber. Actually I am using a minimum substep of 60 and a maximum of 100. But, the error still persists. I don't know how to solve it nBy the way, I am using CPT215, because I want to use drager prager plasticity criterion for seismic analysis of my concrete beam-column joint.nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5452
3391
2473
1310
1022
