April 21, 2021 at 11:37 pm
April 21, 2021 at 11:48 pm
Chris Kopetski
Ansys EmployeeThe FDTD convergence testing page is the best place to find tips and methodology to help with convergence testing. A few specific suggestions:
- The simulation volume is larger than it needs to be. Just include about 1/2 a wavelength of space around the edge of the structure
- Start by using a larger mesh so the simulation runs faster
- Add a movie monitor so you can see where the instability in the fields comes from
- Error on Lumerical device
2706
2142
1357
1144
462
