Convergence of nearly incompressible material – non-linear analysis
    • dzz0
      Hi everyone,
      I have a problem with the simulation of nearly incompressible material (v=.495) and i hope someone may help me with this. I have searched older topics but could not find a suitable solution.
      Specifically, this involves the simulation of a radially symmetrical silicone bond between to adherends under tension loading. For this purpose I use a USERMAT based on the Ogden model. Large deflections are activated (NLGEOM,ON).
      I want to increase the maximum displacement i can apply. I already have tested many things:
      - other elements (185,186,187,285)
      - different keyopts
      - finer mesh, which actually makes it worse somehow
      - more substeps and cumulative iterations
      - different type of symmetry and modelling adherends (flexible and rigid)
      - 2D model
      Does someone have another idea to increase the convergence?
      Thanks in advance!
      Kind regards
      Ben
    • peteroznewman
      I recommend using/continue using:
      • Hyperelastic material model
      • 2D Axisymmetric geometry. Axis of rotation is Y axis, surface on + X side of Y axis.
      • Half symmetry at the center of the length
      • Displacement in Y on the end face, with X = 0
      • Linear elements, but not too small. PLANE182
      • Mesh with element shapes that deform to better shapes, not worse shapes. Start as wide rectangles, end up square.
      • uniform reduced integration keyopt, 1, 1
      • mixed u-p formulation keyopt, 6, 1
      • more substeps and cumulative iterations
    • dzz0
      Hello Peter,
      thank you very much for your tips. I will try this.
      Regards
      Ben
    • peteroznewman
      Ben,
      Note that with a half symmetry condition at the center, a 1 mm displacement of the end is equal to a 2 mm displacement of the full length sample.
    • dzz0
      Hello Peter,
      thank you for the advice. I will consider this in the evaluation.
      Ben
Viewing 4 reply threads
