December 1, 2020 at 3:01 pm
Emperor
SubscriberI am doing electromagnetic-structural coupling simulation. The electromagnetic part in Maxwell 3D is done without any problem. But for structural analysis in Ansys workbench getting convergence error. Can I have a suggestion to fix this error in Ansys 18.2?
Please find the attached outfile of solution information.
Thank you,
Mosarraf
December 1, 2020 at 4:00 pm
Forum ModeratorCheck the mesh, check the physics and check the initial conditions. Then try with a smaller time step.n
- The topic ‘convergence problem’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
