March 14, 2022 at 4:56 pm
mertnarinn
SubscriberMarch 14, 2022 at 4:57 pmmertnarinn
SubscriberTransient analysis fixed top roller. I move the bottom roller z direction 1mm. I have defined friction between the balls and the inner surfaces of the cylinder. However, it keeps crashing, can you help with this?
March 14, 2022 at 9:59 pmpeteroznewman
SubscriberIt looks like you trying to simulate a roller ball bearing. What questions about a ball bearing do you have that you need to answer? Most questions can be answered be reference to a ball bearing manufacturer's web page.
In a prior discussion https://forum.ansys.com/discussion/36273/simultaneous-rotational-and-translational-motion-of-the-cylinder#latest you were not successful getting one ball to make frictional contact with one block. I suggest you get that model working before you move on to a more difficult model.
March 14, 2022 at 11:44 pmmertnarinn
SubscriberYou are right, thank you.
2524
2066
1285
1096
459
