Tagged: boundary-conditions, convergence, fdtd, lumerical
February 25, 2022 at 1:00 pm
pierre_fehlen
SubscriberHello,
We are simulating a plasmonic antenna working in the mid-infrared range, with a 2D simulation. We have a problem of convergence with our simulation. We have tried to correct this, and we have found out that the problem could be in the boundary conditions settings. In particular, by playing with the pml settings, we observe that the “alpha” coefficient is crucial for convergence. In “standard settings” alpha is kept at 0, but we see that if we increase it to 1 the simulation converges. However, we also see that the modes of the antenna (which are recorded with a reflectance monitor) spectrally shift if we keep increasing alpha (until a value of 20, then they are stable). If we play with other parameters, the modes shift as well. We would like to understand how we can set the parameters in order to have convergence and a meaningful result.
Regards
February 28, 2022 at 11:24 pmGuilin Sun
Ansys EmployeeWhen PML is close to the waveguide core, or the mode has long tails the PML can affect the mode calculation.
Do you mean the spectrum shifted due to PML? it seems most likely the PML has some strong reflection. Please increase the PML distance. You can view the mode profile in log scale, and check which side has larger intensity at the boundary, then increase its distance .
Please visit this post Ansys Insight: Choosing the most appropriate profile for PML boundary conditions for some info regarding to PML parameters.
- Error on Lumerical device
2620
2098
1327
1110
461
