August 5, 2019 at 6:18 am
ANKITAPUJAHARI
SubscriberHello,
I am using supercritical co2 from NIST database to study natural convection in an enclosure. I have used density-based solver using implicit formulation and the flux type is Roe-FDS. I am starting the simulation from first order. The convergence rate is very slow. What should be done to increase the convergence rate?
Thank You.
August 5, 2019 at 8:40 am
DrAmine
Ansys EmployeeWhy density based solver? Any reasons for that?
Smaller time steps could be helpful there. Do not forget to switch on gravity.
August 5, 2019 at 9:48 am
ANKITAPUJAHARI
SubscriberDensity-based solver is because of the dependence of density on both temperature and pressure near supercritical temperature and pressure . I have tried using the pressure-based coupled scheme but the probe values are oscillating. One more thing, when I used constant temperature condition on the cold wall convergence resulted. But after using convective boundary condition the convergence rate is extremely slow. I have used steady-state solver
2726
2156
1359
1150
462
