convergence problems CFX with FSI
    • xiaoling
      hi all,
      I am using CFX and transient structure for 2 way FSI.
      I encountered the problem as below. when I set the time step as 0.025s,the error was
    • Surya Deb
      Hello, nCan you please check your mesh specially around the region of the initial load?nDo you see high aspect ratio elements to begin with? Also can you apply a load ramp or test with a smaller load value?nAlso can you try to clear the previous solution and test it from scratch?nRegards,nSuryan
