May 1, 2023 at 12:01 pm
Mitul Wankhede
SubscriberHi, I have a added a convergence tool in Static structural. I have selected only the critical geometry surfaces over which I want to do a convergence study. For some reason the convergence tool is being inactive after clicking solve (refer snap 1). FYI I have no open connections in the geometry, if that is required for the convergence tool to work. Also getting this message (plz refer snap 2) once I click on solve. but the convergence tool does not solve still.
May 2, 2023 at 9:27 am
Aniket
Ansys EmployeeThe message you've shown is neither a warning nor an error, it is simply information. What happens when you right-click on the convergence object? have you set the parameters in the details window of convergence object?
-Aniket
May 2, 2023 at 10:21 am
May 2, 2023 at 10:29 am
Mitul Wankhede
SubscriberI referred Ansys help on the convergence tool requirements. It mentions that the convergence tool remains inactive in cases of different order of elements, if the project has downstream and upstream connections, and few other requirements. I tried to nullify those individually and now my model does not have any parameters which is mentioned in the requirements.
I referred this from Ansys learn:
3311
2471
