September 5, 2019 at 9:28 pm
abd fs
SubscriberHello dear experts,
I work with unsteady turbulent flow, with an interval between [0, 0,8]. Normally, I have to get good results when the simulation has reached 0.1 s, as indicated in a reference article, but in my simulation, I get these values when my simulation has reached 0.8 s.
Do you have any tips for solving the problem?
Does this problem come from time step, mesh or something else?
Best regards,
SER
September 6, 2019 at 9:10 am
Ansys EmployeeWe need more information: chances are it's a mix of mesh, settings, initial values and lack of information in the literature (I've found published data & models to be somewhat lacking in crucial details as the author omits things they don't want to share).
September 6, 2019 at 11:03 pm
abd fs
SubscriberDear rwoolhou,
Thank you for your quick answer, my situation is:
Turbulent flow with turbulence model K-W-SST.
At the Y + wall level used, in the other area, I used a triangular mesh
I have two velocity inputs, the first one is a tabular velocity profile, the second one is a sinusoidal function that depends on time, amplitude, frequency thanks to a C language code. I calculated the time step with:
F=45 Hz, Simulation time: 30 periods of the jet (T), Number of time step / T: 200
T= 1/45 = 0.0222, time step= 0.0222/200 = 0.00111 for implicit
Is the way used to calculate the time step is right, mesh quality?
Best regards,
SER
September 9, 2019 at 5:03 am
DrAmine
Ansys EmployeeTine step size might be okay but aspect ratio is quite high. Where are the cells with this high aspect ratio located? What about cell volume change? -
September 9, 2019 at 10:04 am
abd fs
Subscriber -
September 9, 2019 at 12:07 pm
Ansys EmployeeWhat was the mesh like in the paper? What initial conditions did they use?
September 9, 2019 at 12:44 pm
September 9, 2019 at 4:03 pm
Ansys EmployeeHow long does the flow take to get from one end of the domain to the other? I'd use PRESTO! but doubt it'll make much difference.
September 9, 2019 at 4:33 pm
abd fs
He must take 0.1s
More information about my work is divided into two parts:
first case steady flow without jet (velocity inlet) the results are correct.
Second case transient flow add a jet (velocity inlet = sinusoidal function thanks to a UDF) in this case I find a lot of problems.
Do you have any recommendations for solving this problem? I would be very happy.
I am stuck for almost 4 months because of this problem
Best regards,
SER
September 11, 2019 at 8:54 am
abd fs
SubscriberDear experts,
I have a doubt about how the average and the data sampling for the time statistics are activated.
My goal is to record the values by each period (T = 160 Number of time steps) and the averages it contains.
You will find attached files that represent the way I recorded and averaged.
Best regards,
SER
September 19, 2019 at 8:36 am
abd fs
SubscriberPlease guys any help will be greatly appreciated
September 19, 2019 at 11:00 am
abd fs
I found this condition (immiscible phases) in an article because I have two velocity inputs. How can I insert it into my solver?
Best regards,
SER
September 19, 2019 at 12:47 pm
SubscriberImmiscible describes two fluids that don't mix into a homogeneous fluid, for example oil and water. Do the two inlets have different fluids that will separate if left standing?
If you do have two fluids that are immiscible, you would turn on the Discrete Phase Model in Fluent.
September 19, 2019 at 7:00 pm
abd fs
I do not know why they indicated this condition despite the fact that both fluids are air?
Best regards,
SER
September 20, 2019 at 3:09 am
SubscriberWhy don't you ask them.
2552
2066
1285
1106
459
