March 24, 2023 at 4:34 pm
leosibarani1
SubscriberAfter following the tutorial in Fluid Kinematics course in Ansys Innovation Space i found that in mass flow rate flux is not equal to zero. The graphic is not have a bic ocilation anymore but at the end of the iterations (500 iterations) i think that the graphic is going to top. I'd like to ask should i incrase the explicit relaxation factor and add some more iterations because i think it makes the ocilation is lower but need more iterations for converge or can we say that the graphic of mass flow rate flux is show that the calculation is converge?
Thank you in advance
March 27, 2023 at 8:36 am
Muhammad Rizky Pratama Hakim
SubscriberDear Leo,
The CFD solution should satisfy the continuity equation. If the density of the fluid is not constant, it may happen the difference between the inlet and outlet mass flow rates, because the density is changing over time. If the problem is not transient, you should check again your simulation setting to make sure it is already right.
- Features of the check case
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Error Floating Point Exception
- Heat transfer radiation through glass
- Room with Air-Conditioning Vents
- real fundamental difference in true tension body and engineered tension
- Convergency in mass flow rate
- Function mess balance in fluid flow
- Viscous Models
5442
3391
2473
1310
1022
