November 16, 2020 at 8:18 am
saadia
SubscriberI have modeled a cdc nozzle using solid works and now I'm facing some boundaries of protected topologies have been defeatured when I'm meshing my geometry. and I think that's why I'm getting tri mesh. I'm new to ansys. kindly helpn -
November 16, 2020 at 2:55 pm
RK
Ansys EmployeeHello, nCan you please insert an image of the model and also the exact error message so that I could assist you better? Thanks. n -
November 16, 2020 at 5:36 pm
November 16, 2020 at 8:07 pm
RK
Ansys EmployeeYou might want to apply face meshing to enforce quads and also changing the sizing of the entities. n -
November 17, 2020 at 3:11 am
saadia
SubscriberI have applied face meshing and then sizing of each edge but it gives me the same problematic geometry error. I have tried dividing the geometry into 8 and got quads mesh but the curve area is still the problem. can you suggest me something that could work for me?n -
November 17, 2020 at 5:17 am
Keyur Kanade
Ansys EmployeeTry to reduce defeature tolerance in mesh details. nnPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8726
4658
3151
1678
1450
